Removing ABS
  • 500ke30
    • Oct 2004
    • 134
    Removing ABS
    There a possibility that I will have to remove my ABS unit and I have two questions
    1) Is it ok to just cut the harness and cap the exposed wires? (Will the dash light come on?)
    2) Is is necessary to use a non-abs master cylinder or can I use a splitter for the front brake lines?
    Count down to 1,000,000 miles: 490,649 to go
    I don't know why you'd want to remove the ABS unit. But if you insist, remove the unit, the module and wiring. You can use a splitter for the front calipers.
    • 500ke30
      • Oct 2004
      • 134
      I'm installing a supercharger on a 24V car and there isn't a lot of room in that corner. I haven't removed it yet. I just want to know what my options are.
      • george graves
        • 20003
        I don't know why you make it sound like this is such a bad idea....?
        Originally posted by Matt-B
        • 500ke30
          • Oct 2004
          • 134
          Removing the module wasn't as big of a deal as I thought once I figured out how to disconnect the harness from the module. I left the wiring in the car and used a splitter for the brake lines, as suggested above.
          • 87_black_325is
            • 92
            Any way to avoid the dash light being on as a result?
            87 (OO=[][]=OO) 325iS
            Originally posted by mkcman17
            My car is powered by hopes and dreams
            • george graves
              • 20003
              Pull the bulb?
              • 500ke30
                • Oct 2004
                • 134
                My light never came on.
