CAB Install Lube (Caliper Lube)
  • FrustratedMunky
    • Apr 2004
    • 360
    Hey guys,
    Quick question: Is it okay to use caliper lube on the CAB when installing the new ones? Will it deteriorate the rubber? Will it evaporate? How long should I let it sit until I can drive it?
    I don't want to let the car sit for 24 hours before I can drive it, will this make the waiting period shorter?
    Thanks in advance
    '91 E30 M42 DIAMANTSCHWARZ
  • EverWiser
    • Aug 2004
    • 313
    If it's petroleum based it will harm the rubber...As long as it isn't you should be OK...
    • AdamF 88iS
      • 2051
      Use soap and water.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
