As title says, I pumped it prior to bleeding, opened the valve, then pumped again and nothing came out. Wut?
Rear brakes aren't bleeding
Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Tags: None -
I take it this happens with both rear calipers? If that is the case, crack the line to the rear brakes at the ABS unit. If you can't get fluid out there, crack the line for the rear brakes where it enters the ABS unit. If that doesn't produce fluid, the master cylinder is bad. If you get fluid going into the ABS, but not out, the ABS unit is bad. If you get fluid out of the ABS unit, but not at either rear caliper. the bias valve is plugged, or the line to the rear of the car is obstructed.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Ok thanks, I'll try this tomorrow.I take it this happens with both rear calipers? If that is the case, crack the line to the rear brakes at the ABS unit. If you can't get fluid out there, crack the line for the rear brakes where it enters the ABS unit. If that doesn't produce fluid, the master cylinder is bad. If you get fluid going into the ABS, but not out, the ABS unit is bad. If you get fluid out of the ABS unit, but not at either rear caliper. the bias valve is plugged, or the line to the rear of the car is obstructed.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
How weird. I didn't do what jlevie said yet because I had work yesterday so I had no time, but last night I was chasing another car around twisties with a lot of hard braking. By the end of the night, I noticed there was severe brake dust on my left rear wheel, and some on my right rear wheel! So I guess the brakes do work..occasionally..under heavy braking? :loco:
But I'll get back to diagnosing why it's not bleeding.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
I hope you actually did those above steps.
And why are you even doing spirited driving without properly bled brakes?
If you did in fact do the above process, you should just track the lines piece by piece.
Open the rear valves and pump, if no fluid
Disconnect the soft lines and pump, if no fluid
Disconnect the hardlines at the tee, if no fluid
You get what I'm saying.2008 335i - n54b30
1991 318i - m52b28
1994 fzj80 - LAND CRUSHERComment
I mean, I did know the limits of my brakes, though you're right it's not necessarily a smart idea.I hope you actually did those above steps.
Where would the soft and hard lines be at? :/
Thanks.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
Although the brakes wouldnt necessarily fail, they can possibly not respond as you'd like them too. Just be safe ya know!
Soft lines are the ones connected to the calipers, and the actual hardlines are well, the hard brake lines.2008 335i - n54b30
1991 318i - m52b28
Eek I should have probably done that! It's probably blocked! Which can explain the rear brakes only working when I'm braking real hard..
I feel you on that one!
And yeah I figured once I actually was looking at the brake assemblies..I felt a flexibility line and then I felt a hard line and I was like "oh..well I guess that's what he was talking about.."
time to get back to fixing this brake problem! Thanks guys.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
Awesome, just as I'm about to bleed the right rear caliperthe bleed screw breaks off flush with the caliper! Can I bleed it from the softlines? If so, how?Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
Rebuilt calipers are available for ~$30 with no core. Just replace them, along with the hoses.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
Well that's going to be a bitch. It's cut off flush with the caliper.. time to get creative with the dremel and make a notch for a flathead :(
Where at? Pelican parts only has front rebuilt ones.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
