Setting rear toe
    Setting rear toe
    Installed adj. plates for rear camber & toe. Any help on a good starting point for toe? 1/16 in ? Car is 89 I DD+ GC coils so car is lowered, AKG 80d subframe bush, OEM RTAB. TIA
    My CA legal M60 swap
    The happening in our garage
    Straight dude. A little goes a loooong way in back.
    -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
      For track use, 1/16" total toe and 2-2.5 deg negative camber should be a good starting point. For street use the same toe and 1.5-2 deg camber.
        Thanks for the help !!
