I just replaced the front lower control arms, control arm bushings (OEM rubber M3 offset), and inner/outer tie rods on my '87 325e. The job was remarkably easy compared to some of the horror stories I've read online. I adjusted the new tie rods to be the same length as the old ones, but I know that due to the added caster, an alignment is definitely needed.
Once I got the car back together, I decided to drive it down the street just to make sure everything was put together properly, and immediately turning out of the driveway, the steering wheel wanted to continue turning instead of returning back to center naturally. The steering felt kinda "vague" too. My immediate thought was that I left the lug nuts loose, but nope. I checked everything underneath and it's all tight, no play anywhere.
I drove it down the street and it felt very wandery. WTF, I thought the additional caster is supposed to make straight line stability better! The only thing I'm not 100% sure of is whether the M3 CABs were oriented correctly. I think they are -- the holes on the bushings are oriented to the outside of the car, which in turn moved the front of the control arm forward giving more caster. That's correct, right?
I'm hoping I'm just being paranoid and the alignment is the issue. This presents a problem for me though as my car isn't street legal and I was planning on flat towing it to the alignment shop (I have a tow bar that I bolt to the front end), and I don't want to do this with a whacked suspension since the caster and returnability to center is what keeps the front tires straight while towing. I suppose I could check the toe first.
Opinions?
Opinions?
