Just finished buying everything for the brake job.
After flipping through all the posts on here, I decided on OEM rotors (Brembo), Mintex red box pads, and IE SS lines. All came to the tune of under $250 to my door, so I feel like I got a pretty good deal. Also grabbed a set of OEM ebrake shoes for $18 shipped.
I'm not one that likes doing things more than once. Especially things that require fluids, where if you don't get it right, you have to waste some of that fluid and do it again.
So before I go installing the above parts, what other things should I do before bleeding and refilling the system? Should I bleed all of the old fluid out? If so, what's the easiest way? Go to the driver's front caliper and have someone pump and hold and just let it all out the bleeder?
The brake pedal is soft. The car has been sitting for a while. How can I determine if the MC is still good? How can I check the calipers?
Anything else I'm missing, let me know. Thanks!
