I'm replacing my control arms. I've unbolted the sub frame bolt washer, CAB bolts, sway bar bolt and washer, and the outer ball joint bolt. The control arm is only attached to the vehicle by the outer ball joint bolt.
I let it soak with PB blaster, wedged a pitchfork on the underside to try to pry it out, and pounded on it with a mallet from every direction I can and it won't budge. What am I missing? It's like it's welded in place. I searched, but couldn't find anyone that had this problem...
