E32 master cylinder
  • hurttech
    • 237
    E32 master cylinder
    Does the E32 master cylinder only fit ABS cars? My 84 master cylinder has 3 brake lines going into the MC while the 7 series one has only 2.
  • 2002maniac
    • 4260
    You would need to put a tee in the line to split it.
    I would not recommend the 25mm master though, it's not an upgrade at all.
    • hurttech
      • 237
      Ya did some more research and came to the same conclusion. Would a reman'd MC from a local parts store outperform a "non-leaking" used MC?
        • 37832
        Really? I swapped it on to my 1990 which is still an M20 and I love the pedal feel!
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • 2002maniac
          • 4260
          I guess it's just a matter of personal preference. The extra effort required to do hard braking wasn't worth it to me. After a 20min track session my right foot and leg were exhausted and by the end of a track day I could barely walk straight. lol.
          • Wh33lhop
            • 11705
            I've got a 735i booster and MC and like it. I didn't bench bleed it so there's air in the lines somewhere that I can't figure out, but when the pedal hardens up it seems fine. Supposedly they have a bit more rear bias as well which is also nice.
            paint sucks
            • Massive Lee
              • Sep 2006
              • 6785
              The 735i MC is most likely 23,8mm vs 25,4mm for the 750iL.
              People wanting to go a bit bigger, but not all out, and with a non-ABS car (3 brake lines) can use a 1989-1990 Porsche 944 S2 23,8mm MC
              massivebrakes.com
                • 37832
                Good to know, thanks Lee!
                Grover Beach, CA
                www.BimmerHeads.com
                • hurttech
                  • 237
                  Would the brand of booster matter when using the 944 MC?
                  • Holland
                    • Nov 2008
                    • 7212
                    Any more info on this? I'm looking for a decent upgrade on my M10 car.
                    Originally posted by DEV0 E30
