Powerflex Urethane Control Arm Bushings and Meyle Heavy-duty Sway Links
  • E30is90
    • Jul 2010
    • 107
    After installing these urethane (purple street compound) bushings and replacing the old stock end links with the Meyle heavy-duty ones, I'm getting a clunk sound when taking a hard turn (mostly left, sometimes right). Having a hard time figuring out where the clunk is coming from. Seems to switch from left front to right front (whether making a left or right turn- more so left). Noise wasn't there before the swap-out. Any ideas as to what may be causing this clunk when the car leans from a hard turn? I also replaced my sway-bar bushings at the same time (BMW stock rubber bushings). Any help would be great!
    Thanks,
    Adam
    over 240,000 miles served
    original owner since Oct. 31, 1989
    Check the upper strut mounts.
