master cylinder and booster interchangability
  • tjmonsen5
    • Jan 2006
    • 232
    My buddies has an 85 325e. HIs master was leaking into his booster. The brakes had basically failed. So, i found him a good master cylinder and booster from a 318is because I thought all masters and boosters were interchangeable. He gave the car and the 318is brake setup to his mechanic, and the mechanic said the setup wont fit, or wont work. I dont know why.
    I thought these were supposed to work on any E30???
    I was told that the mechanic ordered a new master and booster from a local parts store for a total of around 200 bucks, i guess thats a good price.
  • Massive Lee
    • Sep 2006
    • 6785
    We don't know either. You need to tell us a few more details as why the wrencher says it doesn't fit.
    massivebrakes.com
    • tjmonsen5
      • Jan 2006
      • 232
      Im just relaying information that I heard from my buddy. He lives about 200 miles away from me, so im just trying to give you guys everything I know.
      So you are saying that it should fit?
      • Massive Lee
        • Sep 2006
        • 6785
        If the parts are what you say they are, then they should mechanically fit.
        Then again, we have too little info to be of any help. The mechanic should tell why it doesn't fit, and why it doesn't work. A scrap part from a scrap yard is just that. Scrap. Perhaps the parts you took were also in non-working condition...
        massivebrakes.com
        • tjmonsen5
          • Jan 2006
          • 232
          nope, they came from my other friends running 318is, because he did an S50 swap and used a 735 booster/master. The part works just fine.
          I called the mechanic and left a message, we will see if he calls me back.
          • FredK
            • 14761
            Did early model MCs have 3 ports?
            • tjmonsen5
              • Jan 2006
              • 232
              Just got a call back from the mechanic.
              The master cylinder on my buddies 325e has 3 fittings, the 318is master has 2.
              The diameter of master where it goes into the booster is over an inch bigger.
              Could be because the 318is had abs, and the 325e does not.
              • Massive Lee
                • Sep 2006
                • 6785
                The early 325e had optional ABS.
                massivebrakes.com
                • Uliv1c
                  • Jul 2010
                  • 43
                  Must be a girling brake system/ or Ate....
                  • 6gen91
                    • 712
                    Where in illinois are you?
                    • tjmonsen5
                      • Jan 2006
                      • 232
                      crystal lake
