You got poly subframe/diff mounts?
  • badvibrations
    • Feb 2007
    • 447
    How much more diff noise should I be experiencing with poly subframe and differential mounts. I'm getting some clunk in low speeds when disengaging/engaging the clutch, and some moaning/grinding at high speeds combined with high rpm(~85mph, ~5k rpm 4th gear).
    Ive had the same around the same noises with two different diffs(the quality of which I knew not, before installing them). The noise did get a little less intense with the second diff but it was still there.
    Is this normal with poly type mounts? Or do I need a diff?
    thanks
    Equal rights should be all or nothing, not picked and chosen based on what's convenient for ones personal agenda.
  • badvibrations
    • Feb 2007
    • 447
    Really?
    No one knows?
    • QUKBMER
      • 8178
      I went to poly subframe bushings and ruined 3 diffs before going back to regular stock subframe bushings. And change the diff its bad.
      • gearheadE30
        • Jun 2007
        • 3734
        ...and how exactly did poly bushings ruin your diff?
        I've got 40k miles on poly diff and subframe bushings without an issue, but my diff is pretty quiet. You can feel hits to the suspension a bit more, but that's about it.
        Project M42 Turbo
        • badvibrations
          • Feb 2007
          • 447
          Originally posted by QUKBMER
          I went to poly subframe bushings and ruined 3 diffs ...
          I don't see how this it possible.
          • george graves
            • 20003
            <---- scratches head
            Originally posted by Matt-B
              • 37833
              You're on a good one.
              Grover Beach, California
              BimmerHeads.com
              • badvibrations
                • Feb 2007
                • 447
                I dont want to turn this in to unfinishable argument between people who know what they are talking about and one d00d who has a squewed perception on how final drives function. . . .
                I just wanted to know how much noise is normal.
                Merry X-mas
                • Aptyp
                  • 6584
                  been on polyurethan/solid stuff forever now. I don't even remember what stock felt like.
                  Never ruined a diff though.
                  • Holland
                    • Nov 2008
                    • 7212
                    Poly does translate a good bit of noise compared to stock, even on 80A, but I have no radio as well. I'm talking about subframe bushings by the way.
                    Originally posted by DEV0 E30
                    • HarryPotter
                      • Jan 2010
                      • 3642
                      I dunno man he is racerx, sounds like he knows his shit.
                      John F. Kennedy
