So I have been trying to install the treehouse cabs and am running into some issues.
I have the cabs on the control arm but I cannot bolt it back up becuase the the cab is off by a few mms from the guides on the frame. I tried to remove the ball joint from the subframe and used everything short of a grenade to try and get the effin bolt loose. I basically have been soaking it with PB, heating the crap out of it, and using an extended breaker bar. I have even pounded opn the cab to try to get it as snug as possible on the arm. Still fail...
I even got so deperate that dremeled the hard edge ofthe cabs a bit thinking that if I could get 1 bolt through and tighten it down that the angle would help center the cab onto the guides. Again Fail...becuase I dont want to ruin the cab with dremeling.
So this is what I am asking. Should I continue to wrestle with the control arm ball joints and then have to deal with banging on the subframe to drop the ball joint and pickle fork. If so any hints? should it apply pressure to the ball joint with a jack then try to go at the ball joint nut again? or should I let the front subframe sag a bit so I can try to align the cabs then tighten it all back up again?
what are your thoughts?
