I'm due for some new break pads, wear sensor are starting to chirp at me. The thing is, I have so much break dust. It covers my black K1's and they always look dull. I'm running cross drilled/slotted rotors. I'm looking around and haven't really found any that would suit my needs yet. Anyone know of high performance pads that have low dust?
breaaaak pads
Tags: None
You can have high performance and dust, or low performance and reduced dust. Take your pick.
That said, most high performance street pads produce a bit less dust than either OE or track rated pads. Hawk HPS pads aren't bad.
If brake performance is important to you, lose the cross drilled rotors and install plain rotors. The holes in cross drilled pads reduce swept area and thermal mass, thus reducing brake performance. Furthermore the holes are stress concentrators and will accelerate the tendency of the rotors to crack under hard use. Basically the holes are initial cracks of large radius.
The only purpose the drilling has is bling.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
That's my understanding as well, about the pads. Thanks for the suggestion on the Hawk HPSs. As far as the drilled rotors go, it helps reduce heat better than plain rotors. And it helps remove water in wet conditions better than plain rotors. Used to you could argue that it helps to remove gas buildup as well, but with todays pads gas buildup isn't really a problem anymore. I don't regularly go to the track, so cracking isn't an issue. That said, I think slotted is the way to go.Comment
So basically, I agree wholeheartedly with the message but cross drilled rotors do have a functional purpose in some scenarios.Last edited by Wh33lhop; 01-15-2011, 01:11 PM.paint sucksComment
Well, not ENTIRELY bling, as it reduces unsprung rotational mass as well, which is why racing teams have drilled rotors. I am not a proponent of cross-drilled rotors. Stock sized rotors need all the heat-absoribing mass they can get, and the holes do NOT help with cooling as everyone seems to think. On top of all of that, 98% of stock sized x-drilled rotors look retarded, just like people who paint their single-piston sliding calipers (or drums) red.
So basically, I agree wholeheartedly with the message but cross drilled rotors do have a functional purpose in some scenarios.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
That's my understanding as well, about the pads. Thanks for the suggestion on the Hawk HPSs. As far as the drilled rotors go, it helps reduce heat better than plain rotors. And it helps remove water in wet conditions better than plain rotors. Used to you could argue that it helps to remove gas buildup as well, but with todays pads gas buildup isn't really a problem anymore. I don't regularly go to the track, so cracking isn't an issue. That said, I think slotted is the way to go.The car makes it possible, but the driver makes it happen.
