'89 325i. 199,000 Miles. Here's what I need help with - ABS Troubleshooting, Sensor and Ring Cleaning, Soft Pedal Diagnosis. I've searched, but could would still appreciate your help.
ABS Activates and Light
Ever since I got the car I would get occasional ABS activation just after starting while reversing out of my driveway.
Recently my Antilock light will come on after a descent bump disabling the system. It has slowly been happening more consistently.
Today I put the car on jacks to see if it was a loose wheel speed sensor or bad wire. I giggled and pulled gently on the wires to try to get the light to activate. It didn't and when I drove it afterwards my ABS activated with every brake application.
My left front wire has a nasty kink in it where the rubber has cracked. I'm thinking this is probably the culprit as I've read very small changes in electrical current will affect the control module. I've got a friend with an '87 parts car that I can pick up a sensor from.
I'd also like to clean my rings on all four wheels while I'm in there. I can't find any pics or a techinique for this. I was thinking Brake Cleaner or Mass Air Flow Cleaner, but I don't want to assume and mess it up. The only DIY in the DIY section involves the ABS relay. The Bentley Manual shows a diagram of what the ring looks like, but it isn't very helpful. Any tips on this would be much appreciated.
If that doesn't fix it I was thinking replacing the remaining sensors. Then the Relay, then the control module, and lastly the Hydralic Unit.
If you've gone through this, please point me in the right direction.
Slightly Soft Pedal
Ever since I got the car my brake pedal has been slightly soft. If you hold the pedal down with engine running it will sink slightly towards the floor. It seemed like a classic bad Master Cylinder. I've replaced the MC twice and pressure and manually (following the Bentley 12 pump ABS procedure) bled the system at least 5 times. I've also gone out on a gravel road and gone deep into the ABS to get the pump to cycle.I've replaced all the rubber lines with new SS ones. I've never noticed any fluid loss in the reservoir or at any of the components. Any suggestions? Next I'm going to start rebuilding calipers.
Slightly Soft Pedal
