2 Brake questions
  • NC325iC
    • Mar 2004
    • 6565
    2 Brake questions
    1) is the vacuum venturi connected to the booster necessary?
    the Y piece, one end goes in behind the throttle plate, the other into the intake boot, is this piece needed? I am getting the miller intake and therefore the part into the intake boot will just be capped, would it be ok for me to just eliminate this piece, it would improve my booster vac line setup alot.
    2) My resevoir is leaking where it goes into the MC, are these seals replaceable?
    this one i will probably find out on some searching im about to do, this thread is more for an answer to #1.
  • NC325iC
    • Mar 2004
    • 6565
    no one knows if the venturi does anything useful?
      • 37833
      Yes you can definitely delete the part that goes in to the intake boot. I have done it on a couple cars and some E30's did not have it to begin with. You won't notice any difference.
      The grommets where the reservoir goes in to the master are replaceable and pretty cheap.
      Grover Beach, California
      BimmerHeads.com
      • NC325iC
        • Mar 2004
        • 6565
        preesh my neesh, gotta email blunt master.
