need help with rear brake!
  • ClassicSkril
    • 49
    I am in the process of replacing my rear brake pads and rotors and have
    come to a roadblock: everything has been removed, and all that remains is
    the old rotor. It is not fused or rusted to the hub and with the e-brake off it
    spins independently from the hub, however when I try to pull it off the hub I
    feel a hook or spring mechanism inside holding on to the rotor. Any help would
    be very appreciated I have never replaced rear disc brakes every. And my 91
    318 has rear discs not drums btw.
  • Matt-B
    The Waffler
    • 3856
    loosen ebrake cables maybe? could be stuck
      You will probably need to loosen the star adjusters for the rear parking brake. The the hub should clear the parking brake shoes.
      • ClassicSkril
        • 49
        You are correct. That same night I reviewed my manual and had to adjust
        both of them. Thank you
