I started removing my subframe yesterday, well heres what worked:
-Remove muffler
-Remove driveshaft bolts
-Disconnect brake lines
-Disconnect sway bar
I also removed the drivers side trailing arm, because i was having issues with the subframe. The 22mm bolts are also removed. But i cant get the 6mm allen bolts to come off, seems like someone might have resprayed the car over those and they are stuck. If i try to turn them they will strip. So do you have any idea how I can remove these? Can i get the subframe off without taking those 6mm allens off?
-Remove muffler
