Low pressure on pedal when pushing brakes slowly
  • e30vert
    • Jan 2005
    • 1789
    When I press the brake pedal down slowly and in a linear fashion it will go very far down and almost touch the floorboard. However , if I press it quickly then the pedal does not go very far and I get good firm pedal pressure. Inspected front pads. Tons of life left. Brake fluid is not low as the light above the console would be on and its not. Rear pads have lots of life left. No leaks anywhere!
    Whats going on?
    Sometimes I forget and just push the pedal slowly and it goes way down before I can raise the pedal and reapply quicker. Scares me in stop start traffic at times :D
  • trent
    Sounds like master cylinder
    I would also check the rear shock mounts, those can sometimes cause wierd problems too
    • arsevader
      • May 2005
      • 1025
      Is this somekind of inside joke or are you thinking of another thread. :?:
      The Rear shock mounts have no impact on the travle of the brake pedal.
      James
      • trent
        Actually, you are incorrect. Bad rear shock mounts create much more "dive" under braking (as the shock isn't working keeping the rear end down). If an inexperienced driver isn't familiar with the car, this extra weight transfer moves more weight to the front wheels making braking less efficient and different feeling. Just saying, its a valid option.
        • trent
          Just to prove my point a little more here is a graph relating rear shock mount behavior to breaking effect.
          And if you use the radial acceleration formula you can figure this all out...see this
          • arsevader
            • May 2005
            • 1025
            I buy that but I don't buy that bad RSMs are going to cause the pedal to go the floor, no matter how bad they are.
            James
            • trent
              James
              read my god damn physics proof
              • arsevader
                • May 2005
                • 1025
                You lost me at "Just to prove......" ;)
                James
                • AdamF 88iS
                  • 2051
                  James
                  Do you have a sense of humor? Just busting your balls man. Master cyl it is.
                  Adam Fogg- '88 M3
                  Common sense- It's the new 'gifted'
                  • arsevader
                    • May 2005
                    • 1025
                    Hence my original question about the joke. :D
                    James
                    • AdamF 88iS
                      • 2051
                      Trent = the next Ove Kvam.
                      And if you know what i'm talking about you are a true OG.
                      Adam Fogg- '88 M3
                      • arsevader
                        • May 2005
                        • 1025
                        I know Ove but I don't know "OG". Maybe I'm just a dumbass.
                        James
                        • AdamF 88iS
                          • 2051
                          Trent is the bomb.
                          Adam Fogg- '88 M3
                          • AdamF 88iS
                            • 2051
                            James
                            Original Gangsta. Not one of these newbie mofos.
                            Adam Fogg- '88 M3
                            • arsevader
                              • May 2005
                              • 1025
                              James
                              Awsome, I feel special. I've never been called a Gangsta before.
                              James
