e brake tighten or broken???
  • Bothfeetin
    • Dec 2010
    • 340
    when i try to engage it rolls back then feels like it hikes up on the passenger side when it finally stops. so my questions is do i need to just tighten it or is there something else wrong
    #Treadlifematters
  • AndrewBird
    The Mad Scientist
    • 11898
    How far does it roll back? It will move a little as it rolls back slightly, which makes the trailing arms drop. If it doesn't roll more then a few inches, nothing is wrong and you shouldn't worry about it.
    • Bothfeetin
      • Dec 2010
      • 340
      it does moves within inches it probley just needs to be tightened
      #Treadlifematters
        When the parking brake is properly adjusted the car should not move hardly at all as the brake grabs. There could be a problem with the mechanism in the rear hubs, but try adjusting the brakes first:
        1) Lower the hand brake and loosen the cable adjusters.
        2) Working through a lug bolt hole turn the star adjuster until the wheel
        locks using a flat-bladded screwdriver. I just turn the adjuster until it
        doesn't want to turn any more. Then back off the adjuster 12 clicks. Repeat
        for the other wheel. Note that the star adjuster is at the 6 o'clock position
        on later cars, but at the 10/11 o'clock position on an E30.
        3) Raise and lower the hand brake several times to settle the cables. Then
        raise the lever two clicks and tighten the adjusters until the wheel can just
        be turned with moderate force.
