Doing the E-brake
  • lolcantturn
    • 4588
    Doing the E-brake
    How difficult would this be? My emergency brake has no effect at all, even with the cable tightened all the way. The pads are definitely non-existent. How difficult would this be and how long should I expect it to take? Thanks
    Originally posted by TSI
    OEM+
    Twiddling the cable adjusters is the last part of adjusting the parking brake (see below). If the shoes are worn out, figure on at least two hours to replace the shoes and adjusting the parking brake.
    To adjust the parking brake:
    1) Lower the hand brake and loosen the cable adjusters.
    2) Working through a lug bolt hole turn the star adjuster until the wheel
    locks using a flat-bladded screwdriver. I just turn the adjuster until it
    doesn't want to turn any more. Then back off the adjuster 12 clicks. Repeat
    for the other wheel. Note that the star adjuster is at the 6 o'clock position
    on later cars, but at the 10-11 o'clock position on an E30.
    3) Raise and lower the hand brake several times to settle the cables. Then
    raise the lever two clicks and tighten the adjusters until the wheel can just
    be turned with moderate force.
    • AndrewBird
      The Mad Scientist
      • 11898
      Before you bother adjusting it, pull the rear rotors off and check the pads. It's possible they are glazed from driving with the e-brake up. Some sand paper will remove the glazing. Obviously, if the pads are really thin, replace them.
      Then just follow jlevie's instructions for adjustment.
      • lolcantturn
        • 4588
        Much appreciated guys thanks! Definately a "wake up early sunday morning" kinda job.
        OEM+
        • OttoBob
          • Dec 2010
          • 88
          I read somewhere that adjusting the parking brake on the 325iX is different. My 325iX parking brake needs to be adjusted. Any input would be appreciated.
          • DaButt
            • 476
            OP, thanks for asking this- I've been meaning to do it.
            My Ebrake works but I have to pull it up like 10-12 detents. I think Bentley says do it at 5, but I would trust Jim's advice.
            Does seem pretty easy, I need to get crackin.
            /______\_o_/______\
            l{(OO)=[//][\\]=(OO)}|
            \ #___======___# /
            |__/-------------\__|
            "Took me an hour to do this..."
            took me like three seconds to copy/paste it- FOR SCIENCE!!
            Barney Fucking Rubble
            • Driftin
              • Jan 2011
              • 129
              On my 88ix, it was the same procedure. Adjusting wheels are at 10 or 11. If you have not done this before, pull the disk off so you can see what you are dealing with. Also my pads were glazed and needed to be sanded.
