brakes failed: LEAKING FROM SUBFRAME :( ?
  • E30SPDFRK
    • 5695
    #31
    Use a set of brake line cutters to cut it, you don't want sparks flying and possibly igniting the brake fluid (it has a high flash point but it's possible) or run the risk of cutting something else.
    And honestly, as much as it sucks and you don't want to do it, that line that comes from the front needs to be changed too. Judging by how it looks in that picture above it only has a few months of life left before it too blows. I'm sure the line running to the right side caliper isn't too pretty either.
    Byron
    Leichtbau
    • samiam3356
      • Jul 2009
      • 1901
      #32
      pic if it helps
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
      • KVF
        • 297
        #33
        So true. You will be beyond pissed when you have to go back in a few weeks/months to do this all over again.
        • lolcantturn
          • 4588
          #34
          I called up a friend with a lift. I'm doing the necessary brake line now, but in probably 2 weeks before my first track session starts, I'm going to get all copper lines all around. I'm definately not going to do this without a lift as I'll drive myself mad.
          Originally posted by samiam3356
          pic if it helps
          Thanks man!
          I didn't get much done today. I took the line off of the T with it's fitting, which I thought would be the most difficult part. But it wasn't. I struggled for a good 2 hours trying to take out the other hard line fitting to no avail. It stripped because the subframe doesn't allow you to really get your wrench against it "flat." Tried vice grips to no avail.
          So I ended up cutting the hard line and rubber line and placing an order with Blunt for a new SS line. I'm just going to reroute it and secure it in place some how.
          Originally posted by TSI
          OEM+
          • Click
            • 637
            #35
            Originally posted by lolcantturn
            I tried loosening the line on the T-fitting, but it seemed damn near impossible. I kind of stripped it
            Are you using one of these?
            ส็็็็็็็็็็็็็็็็็็็็็็็็็
            I need you to exfoliate my ballsack
            Build Thread?
            • IveGotIssues666
              • Oct 2006
              • 517
              #36
              Since you stripped the old nut just cut the line and get a pair of small vise grips on it. Replace both flare nuts with a new hard line and call it a day.
              I do this crap unfortunately alot more often than id like, i'll have cars (old shit boxes) come into the shop just for service and all of a sudden a line will just blow just my luck I guess lol
              Jared
              • lolcantturn
                • 4588
                #37
                I've actually never seen that tool before...thinking about it now, I have about 3 7/16ths and I could have used the trusty old dremel to make something that looked like that.
                I guess there's always (but hopefully not) a next time :(
                Jared
                Yeah I'm just going to screw the hard line and its fitting to a new SS line and just leave it hanging somewhere there. I'll eventually find a place to mount it once I replace all the lines.
                And godspeed..I honestly can't imagine this getting any simplier or easier the 2nd, or even 5th time.
                OEM+
                • Click
                  • 637
                  #38
                  Year flare nut wrenches are absolutely essential for brake line work. You need to get a grip on all six sides to tighten them down enough properly without rounding them and also for taking said super tight fittings off.
                  Build Thread?
                  • lolcantturn
                    • 4588
                    #39
                    Ghetto.. not too proud of it. Should've gotten a shorter hard line (they come pre-flared which is awesome). Will be redoing it (along with all the lines) once I get access to a lift ;)
                    OEM+
                    • Smelser
                      • Feb 2011
                      • 633
                      #40
                      When you buy your flare wrenchs ( use on all brake and fuel lines, anywhere a nut is seceruring a line. found in any type of hydraulics as well. also some coolant lines may be like that as well)
                      make sure you buy QUALITY!!!! I had a set of craftsman, and the f*ckers will spread and round the nut. I traded them in on a set of Snap-ons (I really wanted to throw the f*cking things in Lake Erie) go with Snap-on, Mac, even the Mastercraft Maxximums are decent (get those at Canadian Tire)
                      spend a little more, get a flaring kit, both bubble and regular double flare, spend some time, practice making them, it may take a bit to get the hang of it. but there is nothing better then braking something like that at the track and being able to repair it within 30 minutes and keep going.
                      sigpic1984 318i Total conversion to a DIRT race car.
                      Check out our build on facebook @ www.facebook.com/brewstermotorsports
