Who here does their own alignment?
  • Pussy30
    • Feb 2011
    • 463
    Ever since I bought this car as a project from the PO it has never got an alignment. I have a bunchhhh of toe in that its almost so bad you can help but say "both your front tires are pointing in". Should I grab a tape measure and try my hand at it or should I take it in to the pro's?
    Thanks!
  • dirty thirty
    • 372
    Take it to a pro but if you don't have any cash do as you please! Wouldn't hurt Tory the tape measure would like to see how it turns out.
    Just out trying to build some boost !!
    Stroked and blown 328i @ 15psi
      Since the only thing you can adjust of a stock E30 is front toe, it is pretty easy to do an alignment yourself. On a street car I'd aim for 1/16-3/32" of total toe in. You need toe plates to get accurate measurements, but they can be nothing more than a couple of pieces of plywood about 6" tall.
      • nrubenstein
        • 3148
        Yes, toe plates are very convenient. Even on cars with real suspensions, I still use toe plates to determine if I need to set the strings up.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • Pussy30
          • Feb 2011
          • 463
          Thanks guys. Yeah I was getting some really bad tire wear when I finnaly got fresh tires. At first I thought it was the positive camber (which also was a problem) from the 5 lug conversion without proper camber plates. But then I realized it was the toe. Anyone have a write up on the proper way to adjust it?
          Thanks again.
          • Bearmw
            • 1323
            Not sure what the 6" high plywood entails. Raise just the front 6" and the measure?
            • bimmerteck
              • 762
              I set the suspension up on the scales first and then align them using strings and a camber gauge. I found some pics of home alignment setups like I use in the thread below.
              http://forums.pelicanparts.com/porsc...alignment.html
              • bimmerteck
                • 762
                think 4 6"x6" pieces of 3/8" plywood,1 placed under each tire. Just enough to allow the tire to move as adjustments are made.
                • nrubenstein
                  • 3148
                  Oy. No, not at all. That would be a turn plate.
                  These are toe plates:
                  http://www.amazon.com/Longacre-Toe-P.../dp/B000VAOHB2
                  And you can easily make your own with some plywood, although you'll probably give up a little precision.
                  • M-technik-3
                    • 18946
                    It's E36 5 lug conversion guys. I have some older IE plates that will be for sale soon.
                    • bimmerteck
                      • 762
                      Sorry I may have the terminology mixed up it's been I while since I was officially "taught" to align vehicles and I only do mine once a year or so unless I'm doing suspension work.
                      • nrubenstein
                        • 3148
                        What does 5-lug conversion have to do with anything here? Even if you mean that he has one, it changes absolutely nothing. Unless of course, he has welded in E36 trailing arms (and no, Z3 doesn't count).
                        • nrubenstein
                          • 3148
                          On a stock E30, since all you can really adjust is front toe, toe plates suffice. It's easier to get the wheel centered by a little trial and error than it is to set up the strings.
                          • M-technik-3
                            • 18946
                            What arms were used? is the wheel placement off so it can't be set in proper placement will make a difference.
                            • bimmerteck
                              • 762
                              OK, that explains it, the only "Stock" vehicle I have is my wife's, the e30 gets everything adjusted since it's running a GC setup.
