subframe out....what the do before i paint it up
  • jrobie79
    • Mar 2006
    • 2526
    Taking my rear subframe out, gonna have it blasted and eventually painted/powdercoated....just curious as to anything I should weld onto it before painting it and what not.
    I will be putting in the camber/toe kits so I got that all set, but is there anywhere to weld some extra metal? Dont really wanna spend money on a kit as I have a bunch of stock and tools to cut it, but figured while its out might as well weld some shit up to it. I eventually plan on putting a ST sway bar kit front and rear, anything I should weld for that in the rear?
    The front wont be done for a month or so, so I'm just focusing on the rear. I read some threads but couldnt really decipher anything specific. thanks
    1991 318i ---- 308K - retired
    The only welding appropriate for a rear subframe would be the weld-in camber/toe adjusters.
    • z31maniac
      • 17566
      You could also do the sway bar tabs on the trailing arms.
      www.gutenparts.com
