Rear camber setting
  • wannaBMthree
    • Apr 2007
    • 601
    Rear camber setting
    Heading to the Line-Up shop tomorrow to get my alignment dialed in with new tires, RTAB's, sub-frame bushings and the dungeon weld in kit.
    I know this topic has been discussed ad nauseam, but what's a good rear camber setting for aggressive DD? How far past stock can you go before tread-life becomes a real issue, any ideas? Would like my tires to last, but with the heavy M30 need some help cornering as well. In the end though, I guess tread-wear is most important.
  • E30SPDFRK
    • 5716
    Fix the toe as best as possible and camber will barely be a concern. 2 degrees is a pretty good performance setting for the rear, although it really depends on the rest of your setup.
    Byron
    Leichtbau
    • 325ix
      • Aug 2009
      • 7783
      I was gonna say, it is toe that kills tires, not camber so much.
      • wannaBMthree
        • Apr 2007
        • 601
        Great, Thanks. So the difference between -0-1* and -2* is enough to notice performance wise but not enough to make a huge difference on tire wear?
        Lowered on IE'3 with Bilstein's and 205/45/16's
          I'd suggest 2deg of camber and 1/16" total toe in.
          • Ant_e30
            • 292
            as for as how far you go before camber really eats tyres etc, i'd say -5 upwards.
            before then provided your align is otherwise sweet then you'll be right
            • wannaBMthree
              • Apr 2007
              • 601
              Cheers Ant, that's what I was looking for
