Swaybar sizes
  • Marcos
    • 100
    Swaybar sizes
    Is there a good reference for the different swaybars on the e-30's. It seems they vary from 19-24 on the front and 12 and 14 on the rear.
    What is the swaybar I most likely have on my 89 is coupe?
    Did a quick search and came up inconclusive.
    I intend to buy the poly replacements.
    ... Greased Monkey ...
  • Mikhail Bakunin
    • May 2011
    • 126
    Stock:
    318i(m10): Front: 18mm Rear: none
    318is(m42): Front: 20mm Rear: 12mm
    318ic(m42): Front: 21mm Rear: 12mm
    325e(pre 9/86): Front: 18.5mm Rear: 12mm
    325e(9/86): Front: 20mm Rear: 12mm
    325i(m20): Front: 20mm Rear: 12mm
    325is(m20): Front: 20mm Rear: 12mm
    325ic(m20): Front: 21mm Rear: 12mm
    325ix(M20): Front: 17mm Rear: 14.5mm
    325ix Touring(M20): Front: 18mm Rear: 14.5mm
    M3(s14): Front: 19mm Rear: 14.5mm
    Aftermarket:
    AC Schnitzer: Front: 20mm Rear: 16mm
    Eibach: Front: 20mm Rear: 16mm
    Suspension Techniques: Front: 22mm Rear: 19mm
    Ireland Engineering (adjustable): Front: 25mm Rear: 22mm
    H&R (adjustable): Front: 22mm Rear: 18mm
    Racing Dynamics Early Style (adjustable): Front: 22mm Rear: 16mm
    Racing Dynamics Late Style (adjustable): Front: 22mm Rear: 19mm
    M-Technik: Front: 20mm Rear: 14.5mm
    • SkiFree
      • Jun 2011
      • 2766
      Just a quick add on... IE makes two sizes, the 25mm-22mm listed as well as a 22mm-19mm not listed
      ADAMS Autosport
