Ebrake help on a 3.73LSD
  • EThirty318i
    • Dec 2010
    • 219
    I'm replacing my '84 318i's complete rear subframe w/ a complete '87 325i conv. 3.73lsd subframe. my question where do i hook the ebrake cables too?? the 318 has drums, and the 325 has disks...
    pictures or diagrams would help
    Thanks!
    found the cables, we cut them when taking the 325i's subframe out during the part out. now my question is, can the 318's ebrake cable work on the 3.73lsd???
  • EThirty318i
    • Dec 2010
    • 219
    bump
    • ROLLingKING
      • Apr 2011
      • 1169
      i can post pics in the morning.. i own a 87 325is and am replacing my left rear trailing arm cause the damn lower shock bolt snapped inside the trailing arm..its jacked up already and u should get a good idea from some pics..its simple though..but hey!
      read my post above urs...i need some advice on how to remove the rear axel and changing the wheel bearing
      m20 is plenty. im simply a drifter.
      build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
      • ROLLingKING
        • Apr 2011
        • 1169
        well after looking at them just now the parking brakes just come down the under body of the car till they get to the point where one goes left and one goes right..mine arent clipped to anything..they come from under the car and go into the hub. the one on the exhaust side has a little burn on the black covered part but theres nothing for it to be clipped to either
          • 37833
          You shouldn't have cut the cables from the 325. You should have left them attached to the trailing arms and installed them in to the 318. You'll need 325 cables I believe. You'll need to take apart the brakes to install them.
          Grover Beach, California
          BimmerHeads.com
          • Danny
            • 14216
            Ebrake delete.
            • 2002maniac
              • 4260
              Yea, you need cables from a rear disc car. disconnect them from inside the car and pull them through the underside.
