subframe and trailing arm torque specs?
  • hypnotoad
    • Jun 2004
    • 15
    what are the torque specs for the 2 subframe mounting nuts and the 4 trailing arm mounting bolts?
  • Jordan
    • 12913
    for the 22mm subframe nuts, as tight as you can get them.
    for the trailing arm 19mm bolts/nuts pretty damn tight, but no need to over do it. They have a locking nut so you don't have much to worry about.
    https://mtechniqueabs.com/
    • redcarbon
      • Apr 2005
      • 213
      as a follow up, are the two subframe nuts self-locking? Do they need to be replaced? The dealership said they would have to special order that nut. I think I remember looking it up on realoem.com and it saying it was a locknut. Can I reuse the nut that came off of it?
      thanks
      318is -gone-
      • Jordan
        • 12913
        Its a crush type locknut. Go ahead and reuse it.
        • Brew
          • 3060
          The torque spec on the subframe mounting bolts is 140Nm.
          The trailing arm mounting bolts are 77Nm, I believe.
          '91 318is
