replacing ebrake cable
  • jrobie79
    • Mar 2006
    • 2520
    So i decided to tackle my ebrake....i got everything disassembled, however when I went to remove the old black sleeve the cable sits in, I couldnt take it out so I just cut it with a sawzall... probably a terrible idea looking back on it.
    well now the tube that comes from the transmission tunnel obviously isnt big enough to get the new one seated inside properly....should I just drill it with a 7/16" drill bit and put the new one in? any other tips?
    1991 318i ---- 308K - retired
    You need to pull the sleeve from the car. Thread it with a tap and run in a bolt. then use a slide hammer to get the sleeve out.
    • jrobie79
      • Mar 2006
      • 2520
      ill take a shot at it tomorrow, I got the old plastic covering out, that shields the actually metal cable, but not that sleeve....is drilling it completely out of the question?
      • Ceeker
        • Sep 2009
        • 2821
        it's plastic, so tapping it will be easy. Do as noted above. I had the same problem but I just got a vise grip as high as possible to where it goes in and turned it. Luckily both came out with little to no effort.
        • jrobie79
          • Mar 2006
          • 2520
          what is plastic? on my new ones, the ebrake cable sits inside a sleeve that is made out of metal, with metal fittings:
