RX7 BBK.. will a ET15 with 25mm spacer clear it?
    • 37834
    How much room is there currently between the stock caliper and the wheel spoke?
    Offset doesn't decide if they clear, wheel design does honestly.
    Grover Beach, California
    BimmerHeads.com
    • 2002maniac
      • 4260
      25mm spacers aint going to hurt!
      • sweet6e30
        • Feb 2011
        • 531
        WHO is this woman ????
        my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
        • IminDiegoTriick
          • Oct 2009
          • 1564
          She's a girl im 'talking' too haha. Well just got shipped out the brackets/rotors/pads now all I gotta do is sand blast the rotors and test fit em
          Fast life fuck slow..Low life for life
          Let the mix flow..Let the night flow
          I'm so gone ✗ ♥ O
          • shoguncro
            • May 2011
            • 115
            Also
            i have brock B1 16x9 et15 allaround i think it will need a 5mm spacer to run those mazda calipers
            and i think that my bbs styling(LOL) 5 7x15 et41 will need a 10mm spacer because of the inner design
            Do you have a e32 750i master brake cylinder ???
            • IminDiegoTriick
              • Oct 2009
              • 1564
              Originally posted by shoguncro
              Also
              OO nice you have brock b1's.
              No I dont have the e32 master brake cylinder. Is it needed? Or does it just make everything better?
              I'm so gone ✗ ♥ O
              • shoguncro
                • May 2011
                • 115
                Because with the BBK you need to push a larger area on the brakes and the pedal with oem master cylinder will not be hard , and will go deeper. with larger master cylinder you increase pedal stiffness and effort.
                Hope someone will confrim that, becouse i have read the whole day about that :D
                du you have brackets ?? i am just manufacturing them and some braded steel hoses
                found this
                • IminDiegoTriick
                  • Oct 2009
                  • 1564
                  Im curious now is this true?
                  I'm so gone ✗ ♥ O
                  • 2002maniac
                    • 4260
                    found this
                    http://www.r3vlimited.com/board/showthread.php?t=53875
                    while this is true of some bbks, it is not the case with the rx7 calipers. piston area is nearly identical to the stock caliper. some people prefer the feel of a larger mc, but it's just a matter of personal preference. i find pedal effort too high with the 25mm mc.
                    • IminDiegoTriick
                      • Oct 2009
                      • 1564
                      So in conclusion 16x9 ET15 Borbet Type A even with a 25mm spacer will not be enough for this BBK. Ask me how I know. fuuuuuuuuuu. I suspect maybe a 5mm spacer on top of the 25mm will be enough.. maybe.
                      I also tried my ACT Ls wheels 15x7.5 Et15 with the spacer and it did not work either.
                      Gotta spend more moneys :(
                      I'm so gone ✗ ♥ O
                      • 619E30
                        • 1753
                        Ian, just sell it to me ;)
                        Originally posted by audiquattrot
                        bimmers b4 b*tches....remember that.
                        1990 Alpinweiss 325i - secret 500whp build
                        2000 Audi S4 B5 Laser Red
                        1990 Nissan 240sx - Drift Missile
                        2006 CBR600RR
                        • 2002maniac
                          • 4260
                          You might be interested in this though: http://www.r3vlimited.com/board/show...&postcount=172
                          I think he ground down the fluid passage a bit, but they should fit.
                          • IminDiegoTriick
                            • Oct 2009
                            • 1564
                            OKay will go to the machine shop to get it grounded out, let you know how the next test fit goes. *crosses fingers*
                            I'm so gone ✗ ♥ O
                            • IminDiegoTriick
                              • Oct 2009
                              • 1564
                              So I just ordered a pair of 8mm eibach spacers
                              I just recently had the nub on the caliper shaved off, along with the mazda emblems.
                              It fits much better, but still needs extra space to spin properly.
                              will update when it arrives next week!
                              I'm so gone ✗ ♥ O
                              • shoguncro
                                • May 2011
                                • 115
                                From wich car have you used this
