help with brake pads!
  • va dirty30
    • May 2011
    • 154
    changed out my entire rotor, hub, and brake pads. ive got everything except the pads put back together. how do i push back the brake piston? because that seems to be the problem
  • Ian Bowers
    • Apr 2008
    • 1120
    big c-clamp is what I used.
    • Philo
      Ich esse kleine Kinder
      • 3334
      I use a large pair of channel locks. Just make sure you put something between the piston and metal. Otherwise, there is a possibility you will chip the piston.
      -tim
      Originally posted by Jordan
      I like the stance
      • vandol
        • Jul 2009
        • 152
        use the c-clamp and the old pad
        325i
        • E30_fiend
          • Apr 2006
          • 7348
          If you don't have a c clamp, install the caliper on the bracket loosely with one old brake pad. Then with a large flat head screwdriver or pry bar, pry against the brake pad and push the pad toward the piston until its all the way compressed. Does that make sense?
          Taylor
          • KVF
            • 297
            +1
            Best method
            • accident
              • 7303
              A caliper piston compressor is like $5 at autozone...
              Moral of this story?
                • 37832
                They're a pain in the ass. Honestly big channel locks are a lot easier to use.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • accident
                  • 7303
                  I always heard this, but I've had much better results with a piston compressor. I guess everybody is different.
                  • sweet6e30
                    • Feb 2011
                    • 531
                    lolz its a single piston POS caliper, just use channel locks and done.
                    my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
                    • E30_fiend
                      • Apr 2006
                      • 7348
                      I use a C clamp at work but if I didnt have that, I would definitely use my method
                      • seatown88
                        • 331
                        I have switched from using a piston compressor to just using channel locks, its nice having pistons that don't need to be rotated as you compress the anymore.
                        Don't forget to check your master cylinder level before you compress the piston to ensure you don't spew out fluid inside your engine bay and garage floor.
