What is the better front control arm manufacturer?
  • mattska
    • Jun 2005
    • 159
    I don't have $ for M3 front control arms so don't even start! my r/f ball joint is wasted and I need to replace the arm. I found Meyle and Lemforder for around the same price. Is either one recommended over the other? or is there a better option?
  • LJ851
    • 7919
    BMW ones are best. If yours are original just replace the ball joints. I use Lemforder.
    Lorin
    The M30 is God's engine.
      Lemforder, definitely.
      • E30_fiend
        • Apr 2006
        • 7348
        Lemforder is the best. If you need a good deal, hit up Dave at blunttech.com
        • xxlbimmer
          • Dec 2010
          • 156
          Jlevie, I read somewhere that e36 are the same as e30 arms. Just that the e36 have replaceable ball joints. Is that true?
          Chris Leone
          chrisleonemotorsports.com
          rollcages and fabrication
          Remember cross threading is the only thing stronger than loctite!!
          • LJ851
            • 7919
            ??? E30 ball joints are replaceable, i have replaced mine.
            Lorin
            • HippyEarly
              • Jan 2010
              • 320
              Had my wheels off today and noticed i have a bad ball joint. My search so far lead me to the contrary. What year was yours? Did they change arms?
              Been with me for 16 years...
              Wish i had more time to play with her
              • Mr Two
                • Jul 2008
                • 590
                I replaced my balljoints. Ordered them through Carquest. ~$150 total, for genuine Lemforder goodness
                • HippyEarly
                  • Jan 2010
                  • 320
                  What year? I just looked at my 86 again and they do not look replaceable. Just checked pelican and all i could find was the whole Control arm assembly?
                  http://www.pelicanparts.com/bmw/cata...pg4.htm#item28
                  Were they pressed into the control arm? The rest of my research has told me they are not replaceable. I believe you that you replaced yours but Im stumped.
                  Also At 150 for 4 ball joints and 200 for two new oem control arms, that is confusing me as well.
                  • bmwguy325is
                    • May 2011
                    • 1263
                    I have always bought the myle ones. The issue I have with them is that I have the tree house loli pops and I have to grind a lil off of them to make them fit.
                    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                    • Jand3rson
                      • 37587
                      Lemforder, period. Buy the cheaper stuff, and you get what you pay for.
                      • ACHTUNG
                        • May 2005
                        • 2397
                        Lemforder. And if you can't get Lemforders I would suggest you get Lemforders as a good replacement.
                        1989 US E30 Cammed S52
                        Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                        • Sagaris
                          • Sep 2009
                          • 2243
                          I got Ocap control arms a year and a half ago and they break in half every day on my way out the driveway:weak:
                          I haven't had any problems so far with them, they were priced halfway between Meyle and Lemforders
                          • HippyEarly
                            • Jan 2010
                            • 320
                            I only found a $20 difference at pelican between Lemforder and meyle. And Lem is what they are saying OEM is and those lasted 25 some odd years.
                            So whats the jive with replaceable or not? I think i've decided to get new ones but confused that some are saying the ball joints are replaceable. I haven't found any...
                            • dinanm3atl
                              • Feb 2007
                              • 7305
                              Meyle is quality replacement. For the E30 though the difference in cost is ~20 dollars so worth going with the OEM Lemfoerder. No reason to go to BMW and get rolled over the counter by buying the Lemfoerder arm with a Roundel on it ;)
