1986 325es
As the title states, the brake pedal goes straight to the floor when first pressed. After the pedal goes to the floor I can pump it 2 or 3 times and it will build pressure, but after you release the pedal for about 30 seconds or so it goes to the floor again. I'm not sure if this could be a vacuum issue or not, as I'm pretty sure that I have a vacuum leak somewhere which causes the idle to sometimes surge. There is plenty of fluid in the reservoir and I haven't found any leaks. I don't know if this will help or not but it does this with the the engine on or not. Any suggestions?
