Brake Questions. Advice please :):)
  • IminDiegoTriick
    • Oct 2009
    • 1564
    I have
    *RX7 Calipers
    *Hawk HPS+
    *New rear Rotors/brakes
    I did not upgrade to..
    *Master Cylinder
    *Stainless steel brake lines
    I just flushed and replaced my brake fluid.. and my brake pedal are spongy!!
    I checked if their are any leaks, none present. I reflushed and replaced brake fluid patiently and efficiently three times to the same spongy pedal.
    My question..
    what the fuck?
    Fast life fuck slow..Low life for life
    Let the mix flow..Let the night flow
    I'm so gone ✗ ♥ O
    • 37829
    First of all, what's a stainless steel cylinder?
    Second, did you pressure bleed the brakes?
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • 2002maniac
      • 4260
      You've got air in there for sure. 4-pots can be a pain to bleed but once you get the air out your pedal should feel at least as good as it did before (if not better due to the fresh fluid)
      • IminDiegoTriick
        • Oct 2009
        • 1564
        Wooops my bad, not stainless steel cylinder, Stainless steel braided brake lines,
        and yes, I have a harbor freight pressure bleeder, I used about 12 pounds of pressure.
        Okay I will just keep trying again, thanks
        I'm so gone ✗ ♥ O
        • IminDiegoTriick
          • Oct 2009
          • 1564
          I guess I have to refresh the calipers, because I just replaced the fluid again.. & the pistons were barely moving.
          expect an order Avery :)
          Please be fast this is my daily driver haha
          thanks
          I'm so gone ✗ ♥ O
          • ROLLingKING
            • Apr 2011
            • 1169
            this is interesting.do the rx7 calipers really make that much of a difference?
            maybe once theyre working u can tell me more. ill have to look up what modifications are needed for em to work on early models.
            And does avery rebuild calipers?? i need to send him some. cause i know exactly where to get rx7 calipers. i just found out about this mod today
            m20 is plenty. im simply a drifter.
            build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
