ABS Delete on an Early Model help
  • ROLLingKING
    • Apr 2011
    • 1169
    So for the past 3 cars ive owned I havnt had ABS. First a protoge, then a a4 and my vr6 jetta didnt have abs either. I was also born and raised in Bflo, NY so i know driving with limited traction.
    My 87 35is doesnt have working ABS and ive always liked it better that way. havnt gottn into an accident because of it either. knock on wood!
    I want to take out all the parts that make the ABS work in my car. It looks like there are hard lines which control this. maybe im wrong. but i want to know if its even possible to delete such an integrated system.
    and are there write ups for this?
    Thanks
    m20 is plenty. im simply a drifter.
    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
    You can replumb the brake lines and remove the ABS unit.
    • nrubenstein
      • 3148
      Or you could fix it and be safer. The fascination with deleting ABS really puzzles me.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • Yngvejos
        • 236
        Fix the abs and use it to brake later into the corners. ;)
        My e30
        • bmwguy325is
          • May 2011
          • 1263
          I was never impressed when my ABS did work. It only have ice mode. Threshold braking is faster than ABS braking into a corner anyways.
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          • Yngvejos
            • 236
            It's handy to use the abs to brake a little into the corner.
            Modern racers that are used to abs from the beginning use this actively. (With a bit more sophisticated race abs systems)
            ABS is also good to prevent flat spots on the tires.
            My e30
            • Holland
              • Nov 2008
              • 7212
              I prefer to use and progress my natural ABS system, so then when I do drive in a car equipped with it, I can fully utilize it.
              Originally posted by DEV0 E30
