Freaking ball joint!
  • reztat
    • Dec 2010
    • 72
    My car is in his second ball joint and bushing refresh! and it has only past a year!, no racing , nothing just DD!...my car is 88' SETA! nothing fancy, stock everything ! even botllecaps!....Has this happen to anyone?
  • Ceeker
    • Sep 2009
    • 2821
    if you buy "cheap" aftermarket parts you'll be in for a change in less then 10k. happened to my bmw tech friend who worked for bmw and decided to go aftermarket.
    You have to go first line Lemforders (oem) in order to get your mileage out of them.
    • bmwguy325is
      • May 2011
      • 1263
      Its the nature of the beast. Even more so cause the sway bar is most liley still hooked to them.
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
        The most likely cause of early ball joint failure is the use of inferior parts. Lemforder control arms are the best, with Melye arms bing the second choice. If you tell us that the replacements were Lemforder we can consider other possibilities.
