Hi Greetings from Finland, my first project story on this forum :)
We started a brake project with my friend for another friend. I am going to have a similar set up under my own E30 as well.
First we pressed new bearings to the control arm
And the installed 5-lug hubs with slightly bigger rear rotor
Then we test fitted Porsche Boxster caliper, which fits surprisingly well with this rotor :)
Here will be a axial/radial type of adapter. We managed to took necessary measurements easily
Started the front end as well. Need to fabricate a spacer here to be able to use 5-lug hub, not a big deal after all.
With 16" wheel this caliper looks rather small. I supppose we're going to use bigger front calipers. Boxster calipers work fine even with BMW 15" wheels...
After all quite straight forward project to do. We have a lot of experience with different Porsche big brake projects.
