So im still trying to figure this out w/o going to a shop.
ABS and cruise control non op
1. ABS relay is good.
2. brake and clutch switches are good.
3. MY BRAKE LIGHTS WENT OUT(blown fuse 6)<----- Bentley says that the control module for the CC gets ground through the brake lights, WHERE? if my fuse blew doesnt that indicate a short? I pulled the rear trunk panel and inspected the wiring and it looks good, I did find this:
It appears to be a killer fuse of some kind, the wire is not blown.
Regarding the CC i disconnected the rear sensor wires under the seat individually then drove, they look like this:
ABS light still on, I know I need to check the front ones, but im hoping someone sees this and has gone through this before.
