is this typical
  • jrobie79
    • Mar 2006
    • 2526
    is this typical
    So I just installed new poly everywhere in the rear (aside from sway bushings), new guibo, new CSB, billy sports, H&R race...etc
    I'm driving today and I hear this awful clanking while going over bumps at relatively low speeds, 0-20mph, and I go to look back there and notice the subframe mounting nuts are loose, (not hand loose, but I did tighten them up about 4-5 full turns with a 22mm socket).
    I know I torqued them when I installed everything the first time, should I use locktite on them or is this a sign something else is wrong?
    1991 318i ---- 308K - retired
    I've never seen the subframe nuts loosen when properly tightened, so I suspect you didn't get them tight enough the first time.
    • jrobie79
      • Mar 2006
      • 2526
      I'll double check when I get home tonight and make sure they are torqued properly.
      thanks again jlevie, your posts have helped a ton
      • kikkoman
        • 197
        Same thing happened to me recently after complete rear suspension upgrade. I thought I had tightened the subframe nut as much as I can during the initial installation but found it noticeably loose after the car settled. I went back inside the rear cabin and pounded the bolts from the top to make sure it settled all the way down and retighten the nuts some more.
