quick question about brakes
  • bastianshaw
    • Jan 2007
    • 2210
    what forces the calipers back open after braking?
    Nothing forces the calipers open, but the release of pressure and motion of the rotor allows the calipers to relax enough so that the pads aren't producing braking force.
    • driftingminor913
      • Sep 2011
      • 358
      i too have a quick question, i noticed that when im braking that the rear is also braking too and i didnt no that e30's brak on all 4's instead of in the front.
      so my question is how do i remove the rear braking n just have the braking power go to the fronts???
      Because V8
      http://www.r3vlimited.com/board/showthread.php?t=282219
      Doing it wrong since 91:wgaf:
      • Wh33lhop
        • 11705
        The calipers/pistons do not really "move" in the way that you are imagining. They sit almost against the face of the rotor applying no pressure until you hit the pedal. Then they apply pressure. If they were really moving that much you would have to press the brake pedal pretty far before anything happened.
        What the hell are you talking about and why on earth would you want to do that?
        All cars brake with all four wheels. Every car worth a damn made in the past half century (more than that) has had 4-wheel brakes. Do not remove the rear brakes. They help stop the car.
        paint sucks
        • Ceeker
          • Sep 2009
          • 2821
          ok...maybe a dumb question here..WTF would you want to do that? maybe remove the calipers all together? now no rear brakes and see how the car works? lol
          • bmwguy325is
            • May 2011
            • 1263
            Disconect the brake lines at the master and plug the holes.
            Im chalking this up to darwinism.
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • bastianshaw
              • Jan 2007
              • 2210
              Originally posted by bmwguy325is
              disconect the brake lines at the master and plug the holes.
              roflmfao
              • driftingminor913
                • Sep 2011
                • 358
                (facepalm) well fuck, i was thinkg more or setting my car up for drift and have slide in a freinds e36 and in mide turn he would be on the brakes but applying gas to keep going through the turn.
                i was thinking some kind of same idea for the e30's tho...lol didnt know it would be that negative. N i dont mean removing the whole rear calipers= dumb
                Because V8
                • bastianshaw
                  • Jan 2007
                  • 2210
                  IE sells a biasing valve look into that?
                  • Highway1
                    • Jan 2009
                    • 773
                    ban
                      • 37829
                      Put down the crack pipe.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • 10Toes
                        Me Father Was A Tree
                        • Jan 2008
                        • 61222
                        Just take the brake pads out of the rear and you will get the sam effect. It will also be cool to do big burnouts.
                        I just ask if you use my way that you post some pics of the biggest burnout you can do.
                        • cabriodster87
                          • Jan 2011
                          • 1042
                          Nothing, they are "forced" to the rotor surface via pedal modulation. Static pressure from the caliper piston seal and dynamic suspension flex does the job.
                          Last edited by cabriodster87; 11-18-2011, 10:45 AM. Reason: ha same thing jlevie said, sorry (must read first)
                          Reich und Roll!
                          • slowe34
                            • Sep 2011
                            • 206
                            Actually, the square cut seal around the piston allows the piston to retract after braking pressure is released. It is also responsible for continually adjusting the distance the piston/brake pads are to the rotors.
                            This is probably more clear: http://www.ucx.com/documents/squareseal.pdf
                            • bastianshaw
                              • Jan 2007
                              • 2210
                              Thanks to all those that replied
