While I'm in there- rear end.
  • shEck3lls0
    • Jan 2011
    • 1154
    I am planning on replacing my diff soon with a 3.73lsd for my turbo build. I also need to replace my rear subframe bushings. What else should I do while I am in there and drop the whole subframe and diff down?
    1989 Alpine 325is 2dr m50 swapped
    Build Thread:
    Current ongoing build. Check it out!
    1991 318is 4dr rallycross
    Rallycross Build Thread.
    1991 Alpine 318is coupe - sold
  • ak-
    • 12422
    Prepare to have a useless 1st and 2nd gear lol.
    1991 325iS turbo
    • Holland
      • Nov 2008
      • 7201
      3 clutch LSD.
      Originally posted by DEV0 E30
      • Wh33lhop
        • 11705
        Originally posted by Holland
        3 clutch LSD.
        3 or 4 clutch (use a Porsche clutch, they're a bit thinner and can fit).
        You may want to get some weld-in adjusters or an adjustable subframe and do that while you're in there. That is, if you want better traction.
        Check CSB and u joints
        Trailing arm bushings
        Diff bushing
        Brake lines (chassis to subframe)
        Depending on your power goals I also might consider revising your decision on a 3.73.
        paint sucks
        • shEck3lls0
          • Jan 2011
          • 1154
          I am only planning on running around 10 psi, maybe 12 tops on an m42. So my whp goals are no more than 220.... for now. haha.
          Build Thread:
          • GDA
            • 446
            Weld in adjustable subframe for camber and toe
            Weld in diff mount reinforcements on subframe
            Rebuild driveshaft and drive axles
            • Mr.SWISS
              • Nov 2005
              • 1251
              That
              And get this
              http://www.ebay.com/itm/BMW-Rear-Bus...item1c2292146f
              Originally posted by 325Projectz
              don't listen to the diagram... listen to mr. swiss.
              :nice:
