My brakes has become really soft and i'm able to push it all the way in while trying to brake. Once i pump it...it gets harder and i have brakes. I've checked for leaks but have yet to find one. I check the reservoir and discovered it was empty so the fluid must be going somewhere. When i put new fluid in...i got a few burbs and bubbles....indicating air in the system. I suspect the brake master cylinder and have search for part numbers in an attempt to buy a new or used one. Various sites list two different master cylinders and of course the one for my car, part # 34 311 1 157 206 (production up to 5/88
seems to be unavailable. Will a master cylinder from 6/88 forward, part # 34 311 1 161 866, fit my car? Could it be the brake booster? brake lines? bad calipers? Any help or advice will be appreciated.
