ABS repair kit?
  • g22
    • 274
    ABS repair kit?
    Anyone buy the ABS repair kit?
    http://www.realoem.com/bmw/showparts...61&fg=10&hl=42
    I have a rolling abs fault code so I was checking the connections and the harness side literaly crumbled in my hands. So, I need to fix this issue.
    How does this repair kit tie into the harness?
    Any other ideas to fix this issue?
    I think the repair kit is the connectors and pins. Another alternative would be to get short sections of the body side from a salvage yard and splice them in.
    • g22
      • 274
      Jim, Splice by just using a connector or do you need to solder the connection? Have you done it to your car?
