Won't stop stopping????
  • Hey-U
    • Mar 2008
    • 560
    I recently added a new M42 with DASC super charger and mega squirt to my ride. Also added was a UUC big break kit. The brakes keep locking up after driving it for a short period. I have had the BBK off and inspected a couple of times. Thought I had it solved. From cold I pull out of the carport to wash the car, left the car running while I washed it so that it would warmed up before I took it for a drive. Goddamn it, the brakes had locked up sitting in the drive way before I even drove the car. Next I turn the car off and the brakes let go.
    Any suggestions would sure be appreciated.
    This could be caused by improper adjustment of the link from the pedal to the booster. If the rod is adjusted too long the booster might not be "shutting off".
    • Hey-U
      • Mar 2008
      • 560
      Thanks jlevie. I haven't tried that one.
      • Weeburn
        • 28
        Please update once you've got it figured out, I'm having a similar issue
        • Hey-U
          • Mar 2008
          • 560
          Hi Weeburn, Do you have the UUC big brake kit?
          • Weeburn
            • 28
            No, they're stock, but I figured if the problem ends up being with the booster/pedal pushrod as jlevie suggested in both of our threads I'd like to know, it might give me an example.
            • BergerNJ
              • Oct 2009
              • 349
              I learned quickly if jlevie gives his opinion on your e30 you listen lol
              too many threads where he makes one or two posts to help and boom problem solved...as long as the op is listening lol
              • Hey-U
                • Mar 2008
                • 560
                Turned out to be a faulty booster. All is good now.
                • 2002maniac
                  • 4260
                  do you have a build thread for your car? DASC'd squirted M42 sounds pretty sweet to me!
                  • Hey-U
                    • Mar 2008
                    • 560
                    I keep meaning to put one together but haven't gotten around to it. The pic is a couple years old and doesn't show the shadow line.Here is the list:
                    1992 BMW 318i Cabriolet
                    LSD 4.27
                    5 Speed G240
                    -Topaz metallic (e46 colour) 2009
                    -M-Tech II body kit OEM
                    -Side marker delete
                    -Factory wind screen
                    -Miro wind screen
                    -M-Tech Shadow line
                    -Motorsport door handles colour matched
                    -Brake light delete
                    -Rear plate filler
                    -All-red tinted tail lights
                    -Seats resurfaced in leather with blue stitching 2009
                    -Motorsport door cards with leather handles and buckets
                    -Leather covered consul
                    -M-Tech II wheel 370mm custom cover
                    -Euro clock
                    -Alpina rims staggered 16 x 8" & 7" refinished 2010
                    -Hankook RS-2 Tires 205/50-16 & 225/45-16
                    -Eibach Pro springs 2009 PN 2010.140
                    -Bilstien sport dampeners fronts
                    -Bilstien sport dampeners rear with IE mounts &
                    over sized rear schock plates
                    -Sparco front strut brace colour matched
                    -M3 control arms 2009
                    -M3 Off set bushings 2009
                    -Guibo 2010
                    -Rear Sub frame with adjustable camber 2011
                    -E36 steering rack 95 M3 2009
                    -Zimmerman cross drilled rotors rear 2010
                    -UUC big brake kit front 2011
                    -5mm HR spacerson front to clear brakes
                    -SST brake lines 2009
                    -UUC short shift kit 2009
                    -ZHP shift knob 2011
                    -Ceramic coated header 2010
                    -Super Sprint cat back 2010
                    -Ungo alarm & keyless entry
                    -Passport SR1 radar/laser detector 2009
                    -CD43 cd player + Ipod jack 2010
                    -Infinity speakers Kappa Pro and Kappa 2009
                    -Boston acoustic amp 2009
                    -Mono wiper 2009
                    -Euro grills
                    -Ellipsiod smillies smoked
                    -Smoked turn signals
                    -All red tail lights
                    -Race skid cross brace
                    -AKG rear subframe bushings
                    -Instrument orange needles and trim rings
                    -Alpina gauge strip
                    -Econo to Boost gauge swap
                    -AFR bar gauge by Red Rocket Labs
                    M44
                    - Installed at 185km on chasis with approx 2k miles on engine
                    - M44 rebuilt head and block with M42 (the crank)
                    - Custom Wiseco 9:1 pistons
                    - Clevite bearings
                    - Rebuilt Eaton M62 all new bearings, seals, and a custom polish and meth proof coating on the rotors all done at High Speed Labs) and is running a 9-10psi pulley
                    - Its plumbed in using the Downing Atlanta manifold through a ported throttle body
                    - Delhi 42 lbs./Hr.Fuel Injectors
                    - Fuel pump upgrade to Walbro 255 LPH (not installed)
                    - Manifold has a custom made phenolic spacer to reduce heat transfer from the head.
                    - Custom Built MegaSquirt LC1
                    - Innovate LC-1 O2 sensor, controller, and gauge
                    - Coolingmist methanol injection
                    - COP coil on plug kit HQ Autosports 2011
                    - Heaterplate delete
                    - e10 Brake fluid reservoir
                    - 16" Spal fan / fan clutch deleted
                    - Powder coated valve cover
                    - K&N filter with CAI
                    - Silicone hose kit
                    - Techni fit stainless clutch line
                    - SACHS Clutch disk 1861661133228
                    - SACHS Pressure plate TYP MF 228
                    - Aasco motorsports Lightweight flywheel 100811-11 (11lbs)
                    • ak-
                      • 12422
                      You're not allowed to post things like that without having a proper thread to back it up man.
                      1991 325iS turbo
