Booster Delete / RX7 Brakes
    Hi,
    Has anyone done this combination? Massive booster delete with Rx7 Brakes kit with no Abs on the e30
    I don't have abs system on my car, but I would really like to eliminate the booster. I have ITB'S and the cylinder closer to the firewall doesn't have a lot of space between the booster and the velocity stack.
    What would be the benefits of doing this?
    How would the pedal feel change?
    Whats the best ratio to use 6-1?
    Thanks
    Please Rate Me:
    http://www.r3vlimited.com/board/show...35#post3283535
    ________________
    1987 332i Track Car (253whp)
    __________________
    are you experiencing fade with your current setup now?
      Actually I have to rephrase what I said.
      I experience fade with the stock disc and HP+ Pads, braided lines and Ate blue liquid.
      Now I'm installing new brake ducts, rebuilt RX7 calipers, Hawk HT-10 pads, Slotted and cross drill Vw Corrado disc and bleeding everything.
      But I also live in PR where two Sundays ago the temps during the day were around 90+ in a dry area in the south of the island so probably the temp at the track was 100.
      If I ever experience fade again with my new set up something is wrong with me or the car!
      Please Rate Me:
      ________________
      __________________
