Quick way to tell if Stainless Steel Brake Lines are DOT approved is if they have the clear plastic sheath and the black end piece (has D.O.T. stamped on it). Lines that are not DOT APPROVED will have NO black end pieces.
Picture of black plastic DOT piece (you can kind of see where it says D.O.T. at the top)
Picture of NON-DOT approved lines (no black end cover)
You'll find that some seller's will try to say something like "Made to meet 'stringent' DOT standards", this should be a Big Red Flag. It needs to say 'DOT Approved'.
Ireland Engineering, UUC, and BLUNT all currently use the same Made-in-the-USA source.
EDIT: Guten Parts, Turner, Rogue, BMP, BW, Stoptech, are also all reputable sellers.
If you find someone selling a complete kit for under $90-$110 (for the 6-line E30 kit) then chances are near %100 that it is either the cheap/faulty china lines, or simply not DOT approved. Keep in mind that Non-DOT lines do NOT necessarily mean made-in-china, there are nice none-DOT lines made by the same US manufacturers as the DOT lines, only way to be sure is to simply ask for the 'country of origin'.
The vast majority of Stainless Steel brake line failures can be attributed to either poor-quality lines or installer error.
