Wtf is this on my brake pad?
  • peytonracer4
    • May 2011
    • 524
    I'm trying to install a sensor on my fronts because it's just not there. Is seems like there's some spring in its place.
    What is this? How am I supposed to install the sensor now?
  • kennyvb
    • 404
    The spring is probably the retaining spring for the sensor
    '04 Toyota Sienna AWD (sold)
    '86 BMW 325 coupe (owned since 10/11)
    '05 Subaru WRX sedan (sold)
    '86 Subaru GL-10 wagon (sold)
    '98 Acura Integra GS-R hatchback (sold)
    • PNWDan
      • Feb 2011
      • 1326
      The sensor and spring usually go together.
      1987 Alpinweiß 325is
      Like the PNW E30 Local Crew Facebook page
      • peytonracer4
        • May 2011
        • 524
        wow i'm a moron. i meant to attach the picture of it.
        if the spring and sensor go together i'm confused. how do i get the sensor in there?
        • luTTz
          • May 2007
          • 204
          The sensor has a little metal nub on it that fits into the hole directly in the center of that spring. you'll probably have to remove the pad and squeeze it in with a pair of pliers.
          • peytonracer4
            • May 2011
            • 524
            oh i think i see.
            so this is a rear sensor:
            and this is a front sensor?
            • luTTz
              • May 2007
              • 204
              correct.
              • peytonracer4
                • May 2011
                • 524
                correct.
                Alright good. Is it impossible to insert the sensor without taking anything apart? It seems like I'd be able to stick it in as is.
                • ButtJuice
                  • Dec 2009
                  • 2609
                  You have to take your brake pads off then insert the sensor. Take your time and figure out the placement, it's not that hard.
                  Pad off, place sensor in slot (you don't need any tools to do so), put pad back in & drive.
                  1991 318is - Sold
                  1986 325 - Sold
                  Instagram - Lamoursum
                    • 37834
                    Jesus, just pull off the caliper. It's 2 bolts.
                    Grover Beach, California
                    BimmerHeads.com
                    • Madhatter
                      • Oct 2004
                      • 966
                      Its not even 2 bolts. You only need to remove the bottom one and you can hinge the caliper up and remove it with the top slide still in place.
                      To the OP. If your pads were new you could probably get it in there without removing the caliper, but its tight otherwise. It's an easy job to do though.
                      Just a little project im working on
                      - http://www.lse30.com -
                      • peytonracer4
                        • May 2011
                        • 524
                        my pads are pretty new. i'm willing to bet i can get the sensor in there without removing the caliper but we'll see.
                        thanks for the pictures. they helped me understand what it should look like assembled.
                        • PNWDan
                          • Feb 2011
                          • 1326
                          Funny thing is, I threw mine away and just jumpered the wires. I hate the idiot lights on these cars. I dont need a sensor to tell me to check my brake pads lol
