socket stuck with motor mount nut
  • immajackuup
    • Dec 2010
    • 1132
    if i loosen motor mount nut the socket easily come out but how will I tighten motor mount nut down?
  • lolcantturn
    • 4588
    Get a shallower socket.........or a u-joint in there, kind of get the socket at an angle on the nut but be careful not to strip it. It's fairly simple stuff.
    Originally posted by TSI
    OEM+
    • immajackuup
      • Dec 2010
      • 1132
      i did use a u-joint/shallow socket but the problem is socket keep getting stuck after tighten down nut.
      • immajackuup
        • Dec 2010
        • 1132
        nvm got it.
        • silence
          • Jun 2007
          • 1824
          glad you got it.
            For the socket to be stuck on the nut once the nut is tight, something must be wrong with the nut, socket, or both.
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              ^ Looks to me it's getting wedged against that spot it's bending when tightened down. Nut and socket may be fine, but length looks to be the issue.
              • immajackuup
                • Dec 2010
                • 1132
                it was wedged against motor mount bracket.
                • redsubdivisions
                  • Feb 2011
                  • 1762
                  Grab yourself a set of ratcheting wrenches next time. I did that with my engine mount swap and it was done pretty quickly.
                  1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                  2012 Passat TDI - DD Duty
                  2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                  • immajackuup
                    • Dec 2010
                    • 1132
                    I do have ratchet wrenches,wrenches,and stuby wrench.
                    • silence
                      • Jun 2007
                      • 1824
                      Immajackuup, thanks for your support, please leave a review on my thread, if anyone else needs a set of solid mounts, powersteering delete or solid CABS hit me up.
