spring compressor tool for CAB installation?
  • ScHpAnKy
    • 1573
    anybody got any ideas for DIY tools for the CAB installation? I got the CABs on to the control arms, but need that extra inch towards the front of the car for proper installation.
    I tried a socket and hammer but I don't have enough room under the car for a good swing, since it's on jackstands.
    91 318i | 87 535iS
  • lbreevesii
    • Aug 2009
    • 412
    I pushed, cursed, and beat my bimmerworld sourced cabs. In the end, sufficient force in the right directions and it isn't too bad. I was expecting it to be a huge waffleswaffleswaffleswaffles when I needed to pull them later, but it went super easy.
    edit: my bad, i take it you're using OE style. All you really can do is lube it up and push/hammer it into place- Press if you take em off the car.
    I don't always wreck cars, but when I do I wreck them into trees.
    91' 318is S50 swap - The Black Widow
    • M-technik-3
      • 18946
      you need a press, Jizo has one at his shop in Springfield. But your in Quincy right? Bit far ask one of the bostonite's on BFc.
      • PNWDan
        • Feb 2011
        • 1326
        have you tried soap/grease on the shaft before install? I did that on our E46 before putting the Meyle HDs on it and they slipped right on. I'm just throwing that out there as a guess because I have yet to have the fun experience on my E30 yet.
        1987 Alpinweiß 325is
        Like the PNW E30 Local Crew Facebook page
        • ChefSkinny
          • 213
          I saw a thread where a guy used some threaded rod and a bent piece of metal to pull it on to the control arm, but now I can't find it for the life of me. Will be watching this thread because I'm in the same boat right now, will be doing this as soon as I have some free time.
          • davem
            • Jun 2010
            • 705
            I used a large tube wood clamp and pickle fork.
            • 36brua
              • 689
              go here for simple tool and how to understeer.com GL
              check the length of all thread you need for your set up. 12" may be too short. Iused 3'8" a bit beefier.
              My CA legal M60 swap
              The happening in our garage
              • PNWDan
                • Feb 2011
                • 1326
                http://www.understeer.com/lcab.shtml
                In the DIY he clearly states to lube with soap and that you can press it on by hand but its easier to use the tool. Like I said.. soap it up and press in on by hand.
                • B-well
                  • 1042
                  i make and sell tolls made directly for removal and installation of FCABs
                  PM me if interested
                  • 36brua
                    • 689
                    have you installed new E30 M3 OEM offset bushings by hand using soap only ? Thnks
                    • ScHpAnKy
                      • 1573
                      ended up just buying the $80 tool since none of the above methods worked, I not only lubed it with soap, but also some silicone grease when the soap wasn't working, also cleaned up the actual mounting point so that it would be smooth.
                      91 318i | 87 535iS
                      • German Audio Specialties
                        • Feb 2012
                        • 374
                        I have, on E30s and E46 and a couple others. However, a quick caveat: I am a beefy guy and have insane hand strength. In a shop full of guys, I was the only one capable, so YMMV.
                        GL!
                        Luke
                        August R3VLimited Special: E3012 "V3" box: $225 shipped
                        Tutorials: Killer $500 Stereo | E30 Vert Dual 8'' Box Installation | E3010 Amp Rack Installation | Radio Wiring and Amp Bypass
                        • PNWDan
                          • Feb 2011
                          • 1326
                          Originally posted by German Audio Specialties
                          I am a beefy guy .
                          GL!
                          Luke
                          ha ha ha
                          • jw 325ic
                            • Sep 2006
                            • 1360
                            Just used this homemade tool for the second time today, first time was a year ago or so. Works great every time and is fairly cheap. Definitely recommended but be sure to use an impact wrench! I used a socket wrench the first time and it took forever.
                            • ChefSkinny
                              • 213
                              dish soap straight and gitterdone'
