Brake upgrade suggestions?
  • BrooklynMW
    • 1263
    The next big job I'm doing on my car is brakes. Right now have stock rotors and calipers on there. Looking to upgrade to something nicer.
    Don't need anything TOO fancy or expensive. I don't really plan on taking this car on the track, so I don't need race spec brakes. However, I am building this car into a nice cruising canyon carver and would like something a little stronger than stock.
    Also, something that looks good behind my Euroweaves.
    Any suggestions?
    thanks!
    '87 325i "Chewey" (RIP, my beloved)
    current:
    '01 e46 325iT "Dot" - #datwagonlife
    '87 e30 325i "Tui" - she has her mother's eyes
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    Uuc bbk seems to be a nice sporty setup , I think you do need to change your front pads twice as often though
    88 325is Five Speed
    Lachssilber
      • 37829
      If you want to keep a basketweave style wheel, pretty much no BBK is going to fit.
      The UUC kit is great but I really think you'd be fine with Brembo blank rotors and a nice set of pads.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • KenC
        King of Kegstands
        • 14396
        Refresh your stock system. It'll outbrake nearly every car on the road.
        Originally posted by Gruelius
        • cheapthrills
          • 66
          I agree with others. With a good set of rotors and pads, I don't foresee you being disappointed by your brakes' performance.
          • James Crivellone
            Head Janitor
            • 6304
            Agreed. Upgraded brakes on a street E30 that never sees track time is pretty pointless. If you are REALLY worried about brake-fade toss some decent ducts on the front rotots
            • BrooklynMW
              • 1263
              So here's what I'm gathering:
              -refresh stock rotors and calipers
              -nice pads (any recommendations?)
              -new ducts
              -stainless steel lines
              Good?
              current:
              • James Crivellone
                Head Janitor
                • 6304
                Yup
                I use Hawks on the racecar without any issues.. tad dusty but fantastic braking performance with Brembo blanks
                -new ducts
                Factory ducts work fairly well, although you could whip up a new backing plate and duct direct to the rotor
                Eh, if you want.. on a street car you will never notice the difference. Factory replacement lines are not too expensive either.
                Good?
                • jaywood
                  • Jul 2010
                  • 4528
                  http://www.bmaparts.com/searchitem.epc
                  How do you guys feel about the OPparts rotors?
                  • SkiFree
                    • Jun 2011
                    • 2766
                    No, I'd stick with Ate, Balo, Mayle, Brembo at this point.
                    As for SS lines, you won't notice a difference, but the benefit is that they're pretty close to the same as rubber lines in cost (priced a kit this afternoon) but they'll last a fair amount longer.
                    ADAMS Autosport
                    • KenC
                      King of Kegstands
                      • 14396
                      OEM stuff is cheap and you know it won't crack.
                      BMA stainless lines are cheap.
                        • 37829
                        OPparts stuff is cheapo junk.
                        If you want a decent cheap rotor, the Meyle will fit the bill. I'd go with Brembo though.
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • Bearmw
                          • 1323
                          You could also powder coat your calipers while your at it. As far as pads for street use I think a oem type Pagid pad is the way to go with very good cold performance, low noise, decent fade resistance with good airflow; all in all hard to beat for the street.
                            • 37829
                            Agreed, I am a Pagid fan as well.
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • SpecM
                              • Oct 2005
                              • 4531
                              +1 here too, very very good pad for street/DD
                              I also like PBRs, they are good on a lot of imports
                              1989 cirrisblau-metallic 325i
