rear wheel bearing stuck
  • mr.vang
    • 4371
    i'm about to tackle the rear wheel bearing so i need a wheel bearing tool kit. will this kit work for the rear since it mention front bearing.
    http://www.harborfreight.com/fwd-fro...ers-66829.html
  • flash 23
    • 904
    cant open your link from my phone. but look around for the 25% coupon.
    • jink0619
      • 808
      Worst job ever!!!! in my opinion...GL
      E30love
      • drumad
        • Aug 2009
        • 1700
        that's the kit I used
        2008 335i - n54b30
        1991 318i - m52b28
        1994 fzj80 - LAND CRUSHER
        • nrubenstein
          • 3148
          Super easy with the BMW-B90 tool.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • Wishno87
            • 6025
            That is the kit I used and it was really easy.
            • mr.vang
              • 4371
              thanks guys. heading out to HF
              • wildstoats
                • Sep 2007
                • 896
                I just pulled my wheel bearings last night. In addition to that kit that was already linked I also picked up one of these:
                http://www.harborfreight.com/automot...ator-3979.html
                Makes getting the hub off really easy. Although you could also go to town on it with a hammer, dealers choice.
                • S13_E30
                  • 309
                  I just used a 36mm socket, piece of wood, Hardwood Flooring mallet, and a bit of elbow grease. I heated up the trailing arm a bit where the wheel bearing goes added just a little bit of sparkplug anti seize compound on the wheel bearing. a couple taps and it was in.
                  • jeffmn8
                    • Jul 2010
                    • 217
                    Another thing to make it a little easier.. Stick the bearing in the freezer for 30 min then press it in.
                    Midwest Spec E30 #64
                    https://www.facebook.com/thestickergarage
                      • 37832
                      I like to use the right tool. ;)
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • mr.vang
                        • 4371
                        thanks guys, hopefully everything goes well this weekend.
                        • mr.vang
                          • 4371
                          no luck with wheel bearing. i end up with something like this. i was thinking about getting a new arm with bearing from PNP.
                          • Adrian_Visser
                            • Jun 2006
                            • 2823
                            Those fuckers can be real cocksuckers. I ended up getting a tool made at a machine shop for about $50 that pushes on the outer race. It uses 3/4" ready rod some nuts, some machined plates and a hollow spacer to draw the bearing into. My bearing was so cockstuck in there I was leaning my full weight on the wrench to turn those nuts. You should have heard the bang when it finally broke loose.
                            '89 Alpine S52 with goodies
                            • mr.vang
                              • 4371
                              ^thats what i did but i used spacer to try to pull that fucker out. they all end up with a beating. maybe i need some stronger materiel.
